Design automatic carton box openener
Barts5
Industrial
Oct 31, 2016
11
Hi guys!
Since a few months I work at plant where they make rice.
Now I have to design an automatic carton box opener, but I don't know how to start.
Afther the carton box is filled, it has to be re-openend if there is any quality issue with the rice.
The machine has to cut (or something else) the box to open it and afther that, the machine has to empty the carton box so the plastic bags come out.
All the boxes have the same width but not the same height and length.
One of the targets is also that it should empty 600 boxes/hour but this isn't the main goal.
So if there is a design that could empty less then 600 boxes / hour it's still fine.
I hope you guys can help me,
In the attachment you find a file with the carton box with the platic bags in it.
I would place the boxes face side down on a conveyor and pass them over a rotary knife (say 10" diameter) which slices most of the way through the box, but leaves the back side intact. Subsequently on the conveyor, the slit is opened so the two halves of the box form a "V", and the contents slide out leaving the bag and box empty.
Cutting is relatively straightforward; even the humble box cutter can do that with a correctly calibrated blade protrusion. I don't think it much matters whether you open the box from the top or the bottom, but the bottom is always one wall high, so that seems like a pretty obvious place to cut. So, slice around the box, and lift the top part, leaving the bottom and the bags sitting on it.
TTFN (ta ta for now)
I can do absolutely anything. I'm an expert! faq731-376 forum1529
Thank you for the fast response.
@Compositepro , I also think a rotary knife would be a good idea but I don't understand how the two halves will form a "V".
Is it maybe possible to draw a sketch of it?
@IRstuff I think that when you slice around the entire box, there is the possibility that some carton comes with the bags when you empty the box.
Another problem is that the boxes got different dimensions, so when you slice around the entire box you always have to change the settings of the opener or is there an other way?
Thanks!
Hopefully those examples can give me some inspiration.
>> only if you just bad cutter or cheap boxes. If the box is cleanly cut, it should lift cleanly from the pile of bags and the bottom of the box.
>> You stated that one dimension was fixed, which means that it could be placed perpendicular to the travel of the belt. A blade comes out and cuts the front, two blades cut parallel to the belt, which makes that dimension irrelevant, and some sort of sensor detects the back of the box, stops the side cuts and brings out a blade to cut the back.
It could be similar to 3DDave's video, only the cutting would be along the bottoms of the boxes, which would allow the belt to simply dump all the bags while retaining the bottoms of the boxes on the belt
It is not clear whether the rice is to be removed from the bag as well. I assumed that both the box and bag are to be opened.
Guillotine cutter, falling into a sieve/separator/tumbler to remove carton and bag debris and to shake out the rice. 600 boxes per hour should be child's play.
@Compositepro The installation only have to put the bag out of the box because there is already a machine that seperates the rice from the bags.
@orneynorsk Because rice bags may not be opened I think such a machine isn't achievable.
After some testing I think it's possible to open the box at the top with a rotating knife. Because when I use a normal knife it seems like the box doesn't got enough resistance and folds.
When I try to open the box at the bottom,I always cut in the bags because the box is very full with bags.
What is the easiest way to empty the box after opening it? I'm looking for a way to rotate the box 180°
Box cutting requires some amount of thought. If you're using a typical box cutter with the blade fully extended, then yes, you'd likely cut into bags. The cardboard of a typical box is rather thin, certainly less than 1/4 inch, so your blade should be retracted so that only 3/16" or so is exposed. Secondly, bags of rice, while compliant, are unlikely to get into the bottom corners of the box, hence, your cutter should not be cutting more than 3/16" up from the bottom of the box.
After some testing it seems that a knife creates to much dust.
Seems like I have to find an other way to open the boxes.
Paper dust generation is an unavoidable product of handling paper products. Even systems that don't cut paper will become contaminated. I worked with a mail handling system where the paper dust falling from envelopes needed to be frequently cleaned from the machines. It's understandable considering that paper and cardboard are made of paper dust; it just doesn't look like it because they are suspended in water during the manufacturing process.
There are various systems for blowing dust off things that should be clean and dust collection systems to limit the spread.
I'm using a rotating knife, with cut length 1cm.
You can't see the created dust, but in the lab they tested it and it creates to much dust for the consumer.
Maybe there are possibilities to open the box without cutting? Like 3DDave says, it will also generate dust but a filter can reduce it to a acceptable amount.
Here are some possible solutions to the dust:
1. Slow the rotation of the blade.
2. Try different cutting edge geometries. Sharp and polished will minimize dust. Grind marks on the blade can act as sand paper.
3. Place a vacuum pick-up near the blade.
4. Humidify the cardboard before cutting it. It can be done in storage or as part of the cutting process with a little spray.
5. Make sure the blade rotates toward the outside of the box as it cuts.
If you are cutting the bottom of the box (easy location) I can see an issue of occasionally cutting the bag too (gravity hurts). This EE is picturing a spring loaded container that is as deep as your tallest box. So you'd move the box to be opened to the container, set it on the spring, and then have an arm push it down and hold it at a fixed height. Now when you cut the box gravity has pulled the bag away from the blade (gravity helps).
What would Rube Goldberg do?!
Z
