amain002
- Aug 14, 2013
- 35
Hello everyone. I am seeking for some advice and help to design a decorative ornamental railings. While reviewing the load requirement in the IBC and ASCE, I found these to the basic loading criteria:
i) A uniform load of 50 PLF
ii) A concentrated load of 200 lbs placed at the top of the handrail or guard
iii) Infill to be designed for 50 lbs on an area of 1 square foot.
The railings are basically designed as a custom shape with no end or intermediate posts in between. (I have attached a picture I found in google which appears to describe a similar scenario). In the past, when I designed railing, I applied load at the railings post location and designed post as a cantilevered member.
In this case I am not sure how to distribute the load and design the members since I don't have any posts and my member sizes are typically 1/2" square bars. Does anyone have any experience in designing such railings system. Also, this is for a commercial building and not residential house if it does make a difference.
Thank you all for the help.
