mechengineer
- Apr 19, 2001
- 260
Enthusiast and expert of pressure vessel design.
Let us discuss what the actual design margin is in the pressure vessel design and fabrication.
1. The constant sustained design load are the operating pressure, design pressure and MAWP in pressure vessel design.
2. In terms of primary membrane stress, the design margin (I call 'safety factor') for the allowable stress is the design margin given by the design code.
3. The design margin for the design loads is the difference between the operating pressure and design pressure, furthermore the operating pressure and MAWP.
3a, the design code does not give how to determine the design pressure from the operating pressure.
Whether the allowable stress in the design code is conservative for short period load?
3b, the design pressure often comes from process engineer. My experience is that mostly the design pressure is very far from the operating pressure.
Discussion: Over the past years the code has carefully and rigorously reduced safety margins. However, due to item 3 above not being standardized and rigorous it makes the effort to reduce the design margin by code may be meaningless. Hence I think the code shall not only give the design margin for the allowable stress, but also shall give the rule to determine the design pressure from the operating pressure.
