keen_mentee
I need to design a base plate for attachment of a 2700# equipment to a concrete slab. I also have the operating loads(force and moment) which is greater than the lateral seismic force as it is a SDC B. I wanted to know how we can proceed with the design and have the questions as below:
1. What load would the operational load be categorized as (DL/EL/others) and what do you suggest the load factor in the combination of lateral load with vertical load?
2. How can we determine the thickness of the base plate? So far I am checking the plate in flexure using distance between two extreme anchor points. Is there any check you would recommend?
3. How can we calculate the thickness of the concrete slab under the equipment? I am working with a old template that has the formula as follows and I do not think it it right. The units on the left hand side and right hand side are different too. What do you suggest?
Slab thickness= Load/(0.75*2*sqrt(fc')*Bearing Area of the Plate)
Thank you,
Thank you,
Ruchin Khadka
Thank you,
Thank you,
Ruchin Khadka
