Design of C-shaped and rectangular core walls
fracture_point
58
Does anyone have any good references for the design of C-shape concrete shear walls? I'm looking for specific examples where the analysis and design treats the wall as a complete section, as opposed to splitting it into 3 individual planar walls. I have searched through my design books but can't find any good examples.
Thanks!
Trenno said:
I was thinking more in terms of general multi-wall core arrangements with numerous L and T joints, so as to be able to apply it to all typical mid/high rise cores.
I don't understand are you interested in:
1) How to design the longitudinal joints once you know the forces in a particular wall group OR:
2) How to model the longitudinal joints to find the forces in a particular wall group?
If it's #1, then what I described does apply to high rise buildings with T & L joints.
Trenno said:
What would be a simple way to consider the longitudinal interface shear between the walls when adopting an individual pier/wall design strategy?
I haven't used ETABS much lately. Can you pull the shear value out of ETABS. I know some other software packages can do this. Once you know the shear value you can consider it the same as for a beam. AS3600 covers this in section 8.4. Not sure about other codes though. Generally I have not found it to be an issue for monolithic construction.
I don't think the longitudinal shear is an issue either, you have the same force more or less (depending on reinforcement forces) a little bit round the corner, and a little bit further along the wall a similar longitudinal shearing force. Why is the corner so special? Generally you would expect it to be checked at vertical interfaces between pours, checking shear friction, etc.
Do you check the longitudinal shear force in a monolithic beam shearing horizontally along its length because it has to transfer the top compression to tension at the bottom? Don't think this scenario is any different in principle.
I prefer to look at the entire core for moment capacity, for compatibility you have to (i.e. define pier for extracting moment and axial load for all walls comprising the core). For shear in individual walls you need to define piers on all walls, and check the shear taking into account the axial load in the individual wall pier. As 'flanges will either be in tension or compression. I've seen people design as three separate joined piers but the results are sometimes very odd. Run the inbuilt design tools in etabs with both scenarios and its unlikely you will see the same longitudinal reinforcement for example. Not that I'd trust the layout to etabs at all, prefer to extract forces and use other tools to do the design.
If you are interested in the vertical longitudinal shear, setup section cuts to read this force off straight out of the analysis at the corners, its the only way I know of. Just setup some simple models to get the hang of it and get your head around the sign convention and which valuer is what shear/moment/axial load as its not the most intuitive output to understand.
