James_Gleeson
Can a flat plate beam be designed using as4100? If so, say if we have a 200mmx10mm plate bending about its major axis, what values for d1 (clear depth between flanges), tf (thickness of critical flange) & tw (thickness of web) would you adopt for use in table 5.6.3 (A) twist restraint factor?
