Drapes
- Oct 27, 2012
- 97
I refer to the new concrete code AS3600-2018 under "Section 11 - Design of Walls, clause 11.7.4 - Restraint of Vertical Reinforcement" - see attached excerpt.
With reference to the last statement, does this only apply for walls that are designed as columns, or for walls in general whether they are designed as columns or designed using the simplified method for walls?
The reason I ask is because the preceding statement under this clause relates to walls designed as columns, so unsure if this last statement is simply a follow up requirement, or if it should be read in isolation.
