Chas
- Feb 2, 2001
- 6
I am modifying an existing power distribution box. There is a main fused disconnect (for the box) that sub-feeds two fused disconnects. If the sub-fed fused disconnects are rated at 20A and 25A, what should the main fused disconnect rating be. Also, what should the wire size between the main fused disconnect and the sub-fed fused disconnects be as well.
