I am designing the attachment for PV modules to a roof. I found a very helpful paper that explains how to use ASCE-7 for this purpose, though ASCE-7 is silent on the subject. The example is a near perfect match for my project except I am dealing with a higher wind velocity.
I follow the procedure and get the correct values when working through the example, except my values are positive (+) vs negative (-) as in the example.
The equation is p=q(GCpf-GCpi) q=19, => 19(0.3-(-.69)) = 18.81 but example shows -18.81
When solving for the Downward Pressure (last column) 19(-0.3-(-.69)) = 7.41, again the signs are reversed.
Am I supposed to just know which direction the resulting pressure is and apply the correct sign vs following algebraic rules?
Table 2 and the procedure can be found @
Joe
Joe
