I feel jerky for my original post. What I meant is from my short time on this list, it is more geared towards professionals with specific questions. But by all means, join in and learn. That is what I am here for more than posting questions of my own.
Having traveled and witnessed construction in other countries such as Thailand and Peru (not the Philippines though), the starkest differences to me are economic considerations, lack of building codes or enforcement, availability of materials and the usage of local resources rather than those that are imported, and the availability of cheap but often unskilled labor. And even in the US, a very large difference in construction between metropolitan areas and those in rural areas.
For example, modern skyscrapers dot the downtown skyline of Bangkok, but go an hour in the country and you see bamboo stilt houses. Very similar in Peru with Lima vs Juliaca, where the biggest local industry was homemade mud bricks. I imagine some of the same may be the case in the Philippines.
My point being that as a structural engineer, you are likely going to find employment in Manila or a big city where there is a demand for those services. I am guessing that will entail lots of masonry and reinforced concrete, and some steel design (I'm opining). Differences in labor vs material costs may factor largely into some of your design decisions. So understanding your local market and codes, and learning common construction practices in your area will benefit you greatly, as it does anywhere.
I have seen reinforced concrete and masonry houses in poorer Caribbean islands because that is the material of choice because it is mostly locally sourced, while in the US we build many houses out of wood... Which is better?
Keeping that in mind when soliciting advice from this board, such as the practical considerations in your locality. What we say may work great in Chicago or Vancouver, but maybe that would require a piece of equipment or style of construction that is not practical where you live. I read articles about construction in Europe and Japan and sometimes am amazed by the different techniques and materials versus North America.
But the great thing about structural engineering is on a basic level concrete is concrete, steel is steel, and math and material mechanics are universal.
Cheers and best of luck on your new career!
