Hi All,
I have the un-ideal situation of designing a welded shear tab for some horizontal shear (about a kip or so).
What moment arm would you consider for designing the weak-axis flexure induced in the plate?
My thought is that it would be the "b" dimension I show in the image given that the plate is restrained on 3 sides to the beam web and not seeing much bending.
Additionally, what would you design shear tab to column flange weld for? 5/8 * thickness of the plate per AISC manual part 9?
I can't seem to find any examples of this in AISC literature so references are welcome..
