1
- #1
Screwtape
- Jul 27, 2005
- 19
I'm in the process of designing my first public, FEMA approved tornado/storm shelter. It's in the southeast US and is to be designed using 250 MPH design wind loads. I've run the wind pressures and I nearly fell out of my chair when I saw the loads. I'm currently reading through the FEMA and ICC codes for storm shelters.
The building is approximately 70' long x 30' wide x 14' tall. I was thinking along the lines of 12" CMU reinforced each cell and grouted solid, with closely spaced wide-flange beams at roof level topped with steel deck and concrete. I've attached a working cross section showing the preliminary foundation, wall, and roof framing elements.
The only other issue is the left side of the storm shelter is alongside an existing CMU wall (old Walmart building). Due to the existing footing, the new foundation will be shallow and bear directly on top of the existing foundation. I was thinking about using helical piers for the gravity and uplift loads, as I don't want to overload or undermine the existing footing.
Does all this seem reasonable or should I go in a different direction?
