SubmarinerTom
I have researched for close to a year a very special project and for the life of
me can't get my head around what wing shape to use for my micro-
submarine. Also known as control surfaces, they need to be low drag.
Throw everything you think of conventional submarines out the window.
Most of it does not apply in my design. It is unconventional to say the least.
Think of it as a submarine you wear. A manned torpedo if you will. I have
extensive marine experience in a multitude of disciplines. Jack of all trades,
master of none. What I am looking for is fun, nothing more. No resale, no
drug smuggling, no bombing, no commercial gain, no advice on how to build
or safety issues I need to be concerned about. I need advice on wing shape
AKA control surface design. For this I will be grateful beyond your wildest
imaginings.
The vessel is a NACA 0017 revolved, a tear-drop. ~20 inches at it's widest,
~10 feet long. 500 Newtons of drag at ~15 knots (8m/s). 20"X20" 2-blade
contra-rotating propellers driven by two, 4kW PMSM motors (hollow centre
for "solid shaft in tube" counter rotating drive shafts). One hour dive time
with one hour reserve. Service depth of 30 feet sea water. Delayed ambient
cabin pressure from +/- 1 atmosphere. 42 sealed lead acid batteries.
Displacement is ~600 pounds, buoyancy is -3 to +3 pounds of neutral (the
variable weight of an 80 cubic foot scuba tank of compressed air).
My objective is to fly in the water, in a spirited manner. The trailer is the only
way in and out of the water except in emergency of course, but this would
mean losing the vehicle (vessel, same thing).
I have considered and researched every wing shape possible and can't come
to any definitive conclusion. I would like to employ independent bow planes
1/3 aft of the bow (at the widest point), a full rudder and no elevators.
You may think this thread more appropriate in the marine section but I have
exhausted my marine references and have found them to be, like me, over-
challenged by this design endeavour. I am hoping some aeronautical know-
how will prove fortuitous.
Tom
Victoria BC Canada
imaginings.
Tom
Victoria BC Canada
