struclearner
- May 8, 2010
- 122
For a dynamic simulation of a mechanism having an actuator (Hydraulic Cylinder) as a driver link, to determine the force required for a certain stroke, there are two ways to simulate the job,
1. Activating the mechanism by applying the force to piston and iterations of the force value to complete the stroke in a certain time.
2. Activating the mechanism by giving the motion to the translational joint for a certain displacement.
In the second case, where the force values required for actuator (Hydraulic Cylinder) to complete its stroke, will be determined, in joint of cylinder rod to supporting structure or in the joint of cylinder housing to supporting structure, is that one of the force, will be the same as required to actuate the cylinder. Theese Hyadaulic Cylinders are steering cylindres for turning of the vehicle.
These simulation will be done in ADAMS.
Thanks for input and clarification.
