Hello
Is it possible to determine the distance to a transmitter, from receiver by analysing the wavelength of the signal received?
For example, this process used to determine the location of an airplane. However, is it possible to use the same principles to determine distance or location in a smaller range, say within a metre?
Are there any standard components or common applications that allow for this?
FYI, The application is for a animal/laboratory experiment to track the location of animals.
Thank you in advance for any help
