Please i'd like to know how you can determine the flow rate of a centrifugal pump that you don't have any characteristics,by knowing only:the pressure of the delivery of the pump (2,3 bar), the size of the pipe (50mm diameter),the material (NaOH solution with specific gravity of 1,2 kgr/lt).Is there a formula to calculate the flow rate or is something else needed?
Thank you in advance everyone
