3DDave
Aerospace
- May 23, 2013
- 11,263
I figure there are several ways to determine tolerances for dimensions:
1) Use whatever was on the last drawing someone else did - seems very popular; see title block tolerances.
2) Get QC data for the last several hundred or thousand similar features, picked from an inexpensive process that isn't totally sloppy, calculate a 3 to 6 sigma value and tweak the design accordingly.
3) Get a stress report showing likely levels of force to push parts into place or stresses and deformations induced due to variations in manufacture and choose dimensional variation limits that are acceptable.
4) Make up some numbers because manufacturing will usually use a process that has a 1 sigma chance of making to print and will ask you to open the tolerances anyway, including then moving to a crappier process and asking to loosen them again, while reminding you you held back unnecessarily the first time.
5) Look at the assembly costs and choose values so the parts need no manual alignment, even though the manufacturing estimates are a little higher, saving big in assembly time and fixtures.
6) Dart board.
7) Ouija board.
Just for fun, rank these in order of desirability and then in order of likelihood. Feel free to include other methods that have worked, or might be expected to work better.
6) Dart board.
7) Ouija board.
