Determining volume of hollow part/assembly 1
Spaceballster
NL
Hello there,
Does anyone know of a way to determine the volume of a hollow part/assembly?
The method I'm using now is very cumbersome:
1. Draw the hollow body as a part.
2. Make a new part, use part copy to insert the part and also check the box for construction bodies.
3. Surface copy all of the outside surfaces.
4. Place a small protrusion inside your surfaces.
5. Boolean unite with the created surfaces, you'll have to hide the part copy.
6. SE creates a solid body and you can find the volume in the physical properties.
Griffin
The way I do it is...
Depending on the version prior ST5
1. Draw the hollow body then application button and new assembly
2. Within the assembly create a part in place
3. Edit the new part, using inter-part copy and chain select the interior faces of the hollow body
4. Add surfaces if required and stitch to create a solid body
5. Inspect / Update
With ST5 (just works with parts)
1. Draw the hollow part
2. Add new body
3. Copy interior faces use chain select
4. if necessary add surfaces and stitch to create a solid body
5. Inspect / Update
Best regards
Diego
Diego Moreno
Application Engineer
InterLatin PLM
Well the thing is, it's an assembly by now, consisting of sheet metal parts and a bunch of non-right angles.
I've tried creating a new part, inserting this assembly as part copy (construction surfaces is the only way due to non-zero blabla) and copying all surfaces, or just the outer surfaces. Either way, there are many gaps left and I cannot simply extend the surfaces to fill the gap..
I'm on ST4, service pack 8 btw.
Try using synchronous mode to create a new solid from your imported construction body/faces.
You should be able to just drag faces to create protrusions.
can you post a picture of what we are dealing with?
bc.
Core i5-3570 @3.4GHz , 8GB RAM
Quadro FX4600. W7 Pro 64-bit.
I would probably use the method you have used on that model.
bc.
