MightyJ
Materials
- May 19, 2009
- 13
Hello all,
I am performing corrosion Wt. loss test (ASTM G48) on 4 samples. I will be immersing the entire 6-sided rectangular sample into the solution, however am wondering how I could obtain the corrosion Wt. loss of just the rolled surfaces (2 sides). The other 4 surfaces have been ground down. I realize I could weigh the sample, mask off the ground surfaces, test the sample, remove the masking and weigh the sample again. But was asked to not mask anything off and just immerse the entire sample. And I want to know the Wt. loss of the rolled surfaces for myself. Can any one help guide me through this?
I think the key is that I have 4 samples, two are almost identical in size with the rolled surfaces being equal to the 2 other sides and the 2 ends are about half the size. The other 2 samples both are different in thickness (the ground sides are smaller). The rolled surfaces of all 4 samples are equal. I can post exact dimensions if needed. Any help greatly appreciated.
I'm thinking of coming up with an equation and plotting maybe a ratio of the sides with wt. loss but just not sure how to go about doing this, if it would be right at all.
