mechWatt
- Oct 16, 2013
- 8
Regards to all of you.
I have a small problem that I can't really solve fully at the moment.
I am trying to determine whether there will be a condensation in/on an insulated concrete wall.
I've managed to determine the heat transfer rate thru the wall and temperature between each layer.
Now, this is where I got stuck. I've managed to find water vapour saturation pressure for each of the given temperature between the layers, but I do not know how to determine realistic 'flow' of water vapour pressure thru the wall in order to see if condensation will occur.
The bit of text written below are basics for my calculations, that describe my problem accurately:
Wall consist of a 300 mm heavy rebared concrete (Lambda=1.55 W/mK) and 80 mm of rockwool (Lambda=0.035 W/mK). Temperature and RH are 18 degrees Celcius and 50% on the side of the concrete and 0 degrees Celcius and RH of 90% on the other side (side with rockwool).
I've assumed that convective heat transfer coefficient is 20 W/(m2K).
All of this gives me an U value of 0.388 W/(m2K).
