Sep 30, 2008 #1 boze Mechanical Nov 9, 2002 30 0 0 US How to remove or fix Dgn linetype style 1. Running 2005 LT. Not sure where to find the file, in hopes of deleting it.
Sep 30, 2008 #2 lpseifert Civil/Environmental Oct 13, 2004 260 0 0 US It's part of the .dwg file. You need to remove all instances of any reference to the linetype in order to purge it (blocks, dimension styles, layers etc.). ____________________ Civil 3D 2008, Terramodel Upvote 0 Downvote
Sep 30, 2008 #3 Exxit Computer Aug 18, 2003 804 0 0 DE Yes, you can use "_qselect". Make a copy of your dwg file, explode all. So you can search. Or use "_wblock". Maybe the linetype is not nested... Lothar ADT 2004 Upvote 0 Downvote
