I've been trying to use ASTM A255 to try and calculate DI values and ultimately theoretical hardness profile for a new trial steel grade we are sourcing to make parts of up to 125 mm diameter.
Problem is the new steel grade is 1% C. ASTM only designates for up to 0.7% C... I've tried extrapolating the equations and applying to our higher C chemistry but my results don't seem to match practical observations.
So... 3 questions!
Is there a reason the Grossmann method can only be applied up to 0.7% C?
Is there a similar limit on chemistries in terms of relating Jominy tests to actual hardness penetration?
Is there an alternative calculation that can be applied to higher C steels?
Thanks for any help from a frequent-reader-first-time-poster!
So... 3 questions!
