Adam_c.
- Nov 7, 2019
- 4
Hi everyone,
Has anyone seen behavior like this from a similar motor?
I have a series wound DC motor commonly found in older conversion electric cars.
Its the FB1-4001-A from Advanced D.C. motors in Syracuse NY. This motor has advanced brush timing.
I'm experiencing a very strange problem while testing it. It is pertinent to mention that I'm using an old "Kelly" brand DC motor controller, which works fine with a slightly smaller series wound brushed DC motor I have, so I'm pretty sure all of the symptoms can be attributed to the FB1 motor.
The problem: When I apply constant power power, the motor accelerates and then decelerates hard, then accelerates again. This results in a jerking kind of rotation, which comes to a near stop every 90 degrees.
Facts about the motor: It has four pairs of brushes, offset at right angles to each other.
Thanks for any and all thoughts!
Best,
Adam
The resistance of any commutator pair is very very low, because the motor is so big. Nothing I own has the ability to measure resistance values that low.
The brush timing is advanced, but the problem seems identical to me either way I run the motor. Including the exact four spots where the motor slows rotation. Thanks for any and all thoughts!
Best,
Adam
