Robbiee
- Jan 10, 2008
- 285
Hello all,
Looking to see what works better in terms of the design of a diaphragm chord in a building constructed with hollow-core slabs, CFS stud walls as load bearing walls and cast-in-place concrete shear walls. The two options I am thinking of are:
1- CFS straps at the edges of the slabs.
2- Use the tracks of the CFS studs.
In both options, the chord needs to be continuous. How best to make CFS straps or tracks continuous? is welding a common practices with CFS? If welding is an option, what type of welding or notes are needed to be included on the drawings? I never specified welding for CFS before.
If we use splicing plate/strap to make the chord continuous, we could end up with so many screws to connect the two sides. What did you do?
Thanks for the input.
