strguy11
- Nov 29, 2005
- 232
I have a building with precast concrete walls with metal deck (untopped) roof diaphragm. I have calculated to be flexible.
My questions is that the discussion in the code of rigid/flexible and whether to include torsional effects only appears in the seismic parts of the code. For wind design, can you always consider the diaphragm flexible, and only perform a tributary beam loading analysis to find loads to the shearwalls? And if so, can this be done for the wind loads, even if it would be considered rigid for seismic?
