What is the best position to mount a thermocouple for EGT readings in NON Turbo Diesel applications.
Some variables apply i know like Extractors, in this case is the collector the best position. I suppose this is self explanitory without individual thermocouples for each cylinder.
Also STD manifolds where the exhaust runners merg into one oultet would seem to be best.
The issue i see is the varying lengths of the primary tubes of extractors compared to the short style std manifolds--how much variation in EGT can be expected due to the varying lengths.
Or should the EGT be taken further along the exhaust at a set distance regardless of the type of manifold, extractors used?
Also a word on the correct tune EGT for diesels would be helpful for full load maximum power WOT etc.
Thank you
Thank you
