woody
- Apr 15, 1999
- 3
I have a 60hz 208v generator powered by a 371 cummins diesel. When I got it the DC power wire from the solenoid to the control box was badly burned. I replaced the DC breaker and rewired the bad wire. It was built in 1969 by Condec Corporation. It runs great but I cant control the voltage. I can govern it down and control the hz and the voltage adjusts comparably. The only problem is that I cant get 60 hz and 208v at the same time. The voltage adjust reostat has no affect. It checks out with an ohms meter. Could this be a voltage regulator problem? Any help would be great thanks.....Troy
