JoeFrickinFriday
- Apr 13, 2010
- 16
I'm trying to develop a coarse model of volumetric efficiency (VE) as a function of intake manifold pressure for a heavy-duty diesel engine (~15L). For this discussion, I'm defining VE as the in-cylinder density at intake-valve closure divided by the density in the intake manifold.
I have data from motoring tests that I can use to develop a relationship between RPM and VE, and this is consistent with what I see in numerous technical sources (Heywood, etc.), i.e. the peak value is 86% @1300RPM, and falls off at lower or higher RPM. But I can't get data to help me understand how boost affects VE: when we run the engine with load/boost, EGR is active, and so if I use the air flow measured by the intake air flow meter for my calculations, I get very low values for VE.
So far the only useful info I've been able to find on boost vs VE is from this thread on the Ford Truck Enthusiasts discussion board. Check out the third plot, "Scale Factor for Volumetric Efficiency VE(%) vs BP (psi)". AIUI, this plot means (for example) that for any given RPM, if you run with intake MAP at 3 bar absolute (30 psi on that plot), you won't get 3X as much air into the cylinders as you would at 1 bar absolute (0 psi on that plot); you'll only get (3 x 90.5% =) 2.715 times as much air.
Seems plausible, but I'm having a difficult time finding a citable reference that backs this up. I've got Heywood, but didn't see anything relevant in there Can someone point me toward a published source (book, SAE paper, whatever) that would confirm this behavior?
Thanks...
Thanks...
