Difference between FVNR & FVR type starters? 2
ms9
6
What is the technical difference between FVNR & FVR type of motor starters?
Reversing and non reversing. Reversing takes two contactors, non reversing only one contactor.
Hi Davidbeach
Thanks for your answer. So basically FVNR starter can't rotate a motor in reverse direction where as FVR (two contactors) can change the motor direction. Is it right?
jraef,
did you mean "interactive, voice-controlled starter"? hahaha
