Difference in API607 5th
johnsmith2
114
What is the difference between API 607 4th and 5th edition? We would like to do the fire test on the new valve. Thanks.
johnsmith2,
please take a look at thread182-133010 and other related threads...
Regards, 'NGL
There are two major difference
1. there are high pressure test(75% working pressre) and low pressure test
2. after cooling down.Close the downstream valve.Open the test valve. then measure the external leakage.
Sometimes it's fail because the test valve can't open.
