elecengg010
Industrial
- Apr 17, 2013
- 8
What is the difference in the design of transformer and motor (core and windings) in US (230V,60Hz) and India (415V, 50Hz)?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
In general, 50 Hz equipment is larger than 60 Hz equipment of the same rating. The converse is that 60 Hz equipment used on 50 Hz has a reduced capacity. The ratio is 5:6 or 6:5 and has to do with increased inductive reactance at higher frequencies allowing a higher Volts per Hz ratio at higher frequencies. This allows a higher voltage without magnetic saturation and so a higher ultimate VA.From the motor point of view, the 230/60 would be smaller than the 415/50.
