Jon_Doe
- Mar 30, 2023
- 11
Hi all.
I'm wondering, what are the major differences between an AC compressor and an air source heat pump compressor.
Wen i say AC, i mean small, domestic, split units, not the large industrial ones.
There are a few differences i noticed from studying datasheets but couldn't find more in depth data.
Let's say that both compressor are scroll inverter, to reduce number of variables.
1. AC usually sits in the lower part of the power spectrum while heat pumps in the upper part
2. Newest inverter AC units use R32 and vapor injection compressors (to help when outside air is way below freezing) while air source heat pumps seem to be stuck with the deprecated R410a (with or without vapor injection)
3. AC usually is designed for cooling only (no reversing valve) but there are bidirectional units on the market. Even with the A+++ energy rating, cooling mode has more plusses than heating due to less temperature delta. Even so, there are reversible AC units with A+++ efficiency for both cooling and heating even if most units on the market are A+++/A+ or A+++/A++ for cooling/heating.
If i were to consider the same external circuitry in both cases (TXV, reversing valve, moisture filter, oil system, condenser, evaporator, etc), having normalized both heat pump and AC to the same power, would they perform the same or different (available power and COP at the same inside/outside temperatures?
