Good Day to all,
For Section VIII Appendix 2 Figure 2-4 sketch 6(welding neck), is there anything in code that states the small hub thickness has to be the same as the shell attached? The small hub end is 16mm (sa-105)and shell plate is 14mm (sa-515 70). Also, I did not quite understand why the intentional difference in thickness for design? Thank you.
Yours Sincerely,
L.Y
Yours Sincerely,
L.Y
