different welder approval body
EngrRodri
37
Mates
Our project uses 2 code in WPS which qualified to ASME SEC9(for Piping) & AWS D1.1(for Structural)
My question is if welder is only qualified in AWS D1.1 for 3G position, can he do welding for ASME SEC9 Same 3G position & parameters (Dia, procecess,Thickness,F6 & Pno.) or vice versa...
welder is only qualified to ASME sec9, can he do AWSD1.1 Welding given all range & parameters are same.
Thank you for your feed back
Welders are certified to respective code requirements (ASME and AWS) and are not interchangeable.
