HASSAN NAIM
Hi ,
We are installing a primary/secondary chiller plant . As known , the secondary pumps must be variable speed type and its VFD is controlled by a differential pressure switch .
My problem is where i should install this DPS and what is the optimum pressure setpoint so teh system will work properly and efficiently .
Thank you .
Hassan Naim .
Thank you .
Hassan Naim .
