Normally I use stud bolt A193-B7 size 3/4" for ANSI flange size 6" Class 300.
In one of our projects, the outer ring of spiral wound gasket has diameter 250.8 mm. The distance between center of bolt holes is 270 mm. The case is blind flange of a nozzle. The above dimension seems no problem for installation. But, the gasket cannot be installed in this flange. We have to grind the edge of outer ring to install the gasket.
I understand that bolt hole diameter may be the cause of problem. However, I don't know the tolerance of hole diameter.
- Should we grind the outer ring for gasket installation?
- Can we say that the flange or gasket is deviated from standard dimension?
Please comment.
Please comment.
