Dimension1.GetValue wont work?
Alan Lowbands
Aerospace
GB
Hi Guys,
I have a few bits of script that alter dimensions properties for me.
they work ok on my pc on R18 and I'm sure I have tried them on R21 as well.
When I try them on a work pc running R21 & R24 they come up with
an error "Object doesn't support this property or method Dimension1.GetValue"
any ideas ?
thanks
Alan
I suppose you should post a piece of the script with the error, before give you an answer...
In my (1 month and a half) experience I imagine that dimension1 is a wrong object that does not support that method.
For example if I use ".getCoordinates" with a hybridShapeExtremum instead of a point, it gives that error (in my case it happened).
For some insane reason it's working today ?
I'm using a machine at another company's and it behaves really odd.
thanks anyway guys :)
Could I ask someone to explain the line below?
I keep looking at the automation file but find info like this.
If i understood what it is actually telling me I wouldnt have to bother you guys so much :(
MyDimension.SetTolerances(iTolType, itolName, iUpTol, iLowTol, idUpTol, idLowTol, DisplayMode)
Could someone please give me an example of how you complete the line?
cheers guys
Ok I found some code that I've added to what i already had and it gets the results I need.
Not pretty but it kind of works and I'm slowly (very slowly) starting to get the jist of how it works.
But,
Can anyone tell me why I have to run the script twice before it changes everything?
Sub CATMain()
Dim documents1
Set documents1 = CATIA.Documents
Set Document = CATIA.ActiveDocument
Dim selection1
Set selection1 = Document.Selection
Set Info = selection1.Item(1)
Dim Dimension1
Set Dimension1 = Info.Value
Dim DimTolValue
Set DimTolValue = Dimension1
Dim oTolType
Dim oDisplayMode
Dim oTolName
Dim oUpTolS
Dim oLowTolS
Dim oUpTolD
Dim oLowTolD
DimTolValue.GetTolerances oTolType, oTolName, oUpTolS, oLowTolS, oUpTolD, oLowTolD, oDisplayMode
oTolName = "TOL_NUM2"
oUpTolD = 0.2
oLowTolD = -0.0
DimTolValue.SetTolerances oTolType, oTolName, oUpTolS, oLowTolS, oUpTolD, oLowTolD, oDisplayMode
Dim DimDimValue
Set DimDimValue = Dimension1.GetValue
DimDimValue.SetFormatName 1, "ANS.DIMM"
DimDimValue.SetFormatPrecision 1, "0.100" 'precision
Dim oNoOff
oNoOff=InputBox ( "Enter No Off Holes" )
Dim oNoOffText
oNoOffText = "("& oNoOff &"x) "
Dim oBefore
oBefore =oNoOffText
Dim oAfter
oAfter =" THRO'"
Dim oUpper
'oUpper = "Upper"
Dim oLower
'oLower = "Lower"
Dimension1.GetValue.SetBaultText 1, oBefore, oAfter, oUpper, oLower
Dim myDim 'As DrawingDimension
Set myDim = CATIA.ActiveDocument.Selection.Item(1).Value
Dim myDimLine 'As DrawingDimLine
Set myDimLine = myDim.GetDimLine
myDimLine.DimLineGraphRep = catDimLine2Parts
MyDim.RestoreValuePosition()
End Sub
