Dimensioning
Rednyx
JP
if i have a shape to which i would like to give a general dimension , like a square of side measuring 'a' units, what should i do as all the dimentioning tools actually gives the measurement but not only a symbol. I like to use this quite regularly so i am expecting a quick way for it.
is there a command to draw the central x and y axis of any figure?
After selecting the 2nd point of your dimension, select Text or Mtext
Regards Steven van Els
SAvanEls@cq-link.sr
i am interested to write the text with dimension style ...line with two arrows at the ends
You actually start dimensioning
Command: _dimlinear
Specify first extension line origin or <select object>: _endp of { 1st point }
Specify second extension line origin: _endp of
{ 2nd point }
Specify dimension line location or
[Mtext/Text/Angle/Horizontal/Vertical/Rotated]: t
{ here you specify to modify the default dimension}
Enter dimension text <208.83>: A
{ The character A will be placed instead of 208.83}
{ specify position of dimension line}
Hope this helps
Steven van Els
SAvanEls@cq-link.sr
You can use dimordinate to draw the central x and y axis of any figure but the drawback is you must place the centroid of the figure on the point (0,0). Then when you use dimordinate, you can show a zero dimension from the center. It is a great command for sheet metal dimensioning as well. Tommy
If you are going to dimension linear edges using general dimensions often, you might want to add an extra level of automation to the method Svanels suggested by using a LISP routine. Try adding this to your Acad.lsp file:
(DEFUN C:TEXTDIM ()(COMMAND &quot;DIMALIGNED&quot; &quot;&quot; pause &quot;T&quot;))
You can then create a custom button and assign it the macro
^C^C_textdim. The advantage is that it saves you three keystrokes/buttons (5 instead of 8) each time.
Also, if you are going to be using the same letters repeatedly, you might want to create a LISP command for each letter and assign it a unique button:
(DEFUN C:TEXTDIMA ()(COMMAND &quot;DIMALIGNED&quot; &quot;&quot; pause &quot;T&quot; &quot;A&quot;))
This cuts the number of keystrokes down to three.
