I have an assembly that I'm resizing and then saving the resized model in the Configuration Manager. If I change the model too much, some of my dimensions get flipped. For instance, if I have a hole that is dimensioned 1" to the right of a line and I resize the model, that dimension will now be 1" to the LEFT of the line.
Has anyone else experienced these problems? If so, is there any workaround/solution to this? I am going to be automating this modeling process to resize the assembly for SEVERAL models so I'm not able to check every single model and change the dimension as necessary.
