I've got a file created by somebody else. I then dropped in a PS layout that I've been using.
When I go to dimension the model from paperspace, the dimension is not scaling to model space - it's just showing the actual paperspace distance. If I do my dimension in model space, then the dimension is correct but the text height's all messed up.
I do not have this problem when doing my own drawings with my template but only when trying to work in this other guy's drawing.
I'm guessing there's a system variable that needs to be turned off or on.
Anybody know where I should look?
