DIN 6885 1
robles2713
Industrial
Jun 12, 2008
4
Can anybody tell where I can find the the std dimensions for a 14mm key and keyway (shaft & hub)on DIN 6885.
You could just buy it for $56 at
or you could do your own Google search for
DIN 6885 DIMENSION AND TOLERANCE
and come up with
as the first hit.
Either one would probably give you the answer quicker than waiting for someone else to tell you.
-handleman, CSWP (The new, easy test)
