civilman72
I work in the Rocky Mountains in Colorado. Every water district in my area requires the use of DIP for all water mains (generally 8" in size or larger). They will also allow the use of C900 for water mains. I have been asked by a client to propose the use of HDPE for the replacement of an existing 3" pvc plastic pipe. I know the District's first reaction will be "absolutely not!" These District's are not the most open-minded, mostly because I live in a small community and we do not have the most technically advanced people currently working for these Districts.
I guess my first question is: can anyone tell me why the use of DIP would be so important, especially when compared with HDPE? Please consider the following: I work in very cold conditions, lots of freeze/thaw, also bury these mains at least 8' deep, and the soil types can be very rocky.
I know the use of HDPE pipe is becoming more and more common for water mains, but I also believe it is fairly new in this type of use, so truly understanding it's life span seems to be an issue. From the little research I've done, it seems that the most important part of construction that ensures a longer life-span is correctly welding the joints together. Besides that, the installation seems fairly straight-forward.
Being the local PE that steps up the plate and attempts to educate the local municipalities to change their ways, is a long-standing challenge that I would prefer to not take. BUT, if I did, does anyone have a good reference source to start with?
Any advice or opinions would be appreciated.
