ajk1
- Apr 22, 2011
- 1,791
Does anyone have a formula for the direct tensile strength of concrete?
Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Ron said:Modulus of rupture is done as a flexural test and does not directly measure the tensile strength of concrete. Another commonly used, but also indirect indicator of tensile strength is the splitting tensile test. Both will generally yield a tensile strength of around 10 percent of the compressive strength. Axial tensile strength of concrete is a more difficult test to run and generally yields slightly lower relational value to the compressive strength
ajk1 said:To DamsInc: the test procedure routinely used here in Canada is CSA A23.2 - 6B, "Method of Test to Determine Adhesion by Tensile Load" (I do not know if there is a corresponding ASTM test or not). The CSA test requires that the minimum diameter of the core bit shall be 3½ times the nominal maximum size aggregate size but in no case less than 75 mm". The inside diameter of the core is stated to be slightly larger than the fastening disk. I am perhaps a little surprised that you say that pull-off tests are normally done with 2" (50 mm) disks, as most concrete has 20 mm (3/4") diameter coarse aggregate. Anyway when we do the tests we use 95 mm diameter disks. I don't think that the 20 mm aggregate should then be a significant factor.
ajk1 said:I also appreciate that you have found that your reference book says that
MOR strength > splitting tension > direct tensile. Sometimes the good old fashioned medium is the best! That is what I had thought when I started this string. Can you tell me the reference book that you found that in...maybe we have it in our office library. Is it Troxell & Davis?
