NickParker
We have a LV switchgear where in the Incoming breaker, there is a trip unit which is of LSIG and also have a separate earth leakage relay.
Is it okay to disable the G function of the trip unit and use only earth leakage relay for earth/ground faults?
The reason is the G function cannot be set for low pickup, that is at 5A, while the spec calls to trip at 5A for ground faults in hazardous area.
