Disable "Mate Xpert"
cwsink
Automotive
Sigh...So much for "Enhancement". The MateXpert is about to send me through the roof. I can't control the thing when I try to flip alignment of a mate. It ends up causing more issues than I ever had without it. As far as I'm concerned, scrap the MateXpert and just keep the RMB selections to "Flip Alignment" and "Flip Dimension". Or at least allow the user to control which mates will flip or something. There's no rhyme or reason to which ones it will change. It goes so far as to flip a mate that I'm unsuppressing and other mates I've already setup that do not conflict, after I've already setup the other mates that I want, correctly with no conflicts. I've destroyed more assy's in seconds than I've had it save me time!
Which leads to the question! Anyway to disable the MateXpert?
Craig Sink
Mechanical Engineer
Force Design, Inc.
This probably should work like the sketchxpert does and give you several working solutions to choose from. Instead it just gives you "a" working solution.
Jason
UG NX2.02.2 on Win2000 SP3
UG NX4.01.0 on Win2000 SP3
SolidWorks 2007 SP2.2 on WinXP SP2
Just had a long discussion with VAR. It is covered in the advanced assembly class. The help is sorely lacking and there is a bit of documentation in What's New.
[sad]
TOP
Eek. Scary content in here. IMO, there should be an option to disable it somewhere... if not, they're quickly going to drive the old-school users insane.
