gabimo
- May 2, 2013
- 124
One of our QE claims that in order to get the “correct” datum displacement when parts are measured on the CMM the secondary datum feature (B) is to be measured twice.
Details: Parts similar with 7-24 or 7-26/ 2009
On the initial base alignment, A primary datum feature and B secondary are measured as shown on the drawing (similar with the pictures from the standard). The size of datum feature B is qualified and reported.
Then the size and location of the thru holes are measured. –same base alignment is used .
- On the bonus side we have no disagreement.
- On the datum shift/ datum displacement (from B at MMB) the disagreement is because of how the size of B is measured (UAME versus RAME as explained by the QE, but not understood very well by the CMM programmer and I, as well)
As we were told, B “should” be measured twice -- base alignment (coordinate system on the CMM) shall be changed in such of way (what exactly is the practical method, not understood) that size of B is to be measured perfectly perpendicular to the datum A---
Is the QE correct? And if yes, then why the same feature should be re-measured? Any changes in the CMM algorithm that can be done to avoid redundant feature measurement?
Could you shed some light on our dilemma for the theoretical side and also on the practical side of things?
