DISAPPEARING TEXT, NOT SAME OLD ISSUE
rgajewski
22
We've just loaded a new computer with Inventor 10 and the text does not appear in drawing files. Same as in older threads. Tried the Microsoft update removal that the old thread refernced. Can NOT remove that update. Tried the fix through AUTODESK, could not run them. Went back to AUTODESK's first fix to load all fixes upto the current fix. That also would not allow me to update. I've fixed my system that is about 1 year old. Is there something with a brand new system I'm missing?
Thanks.
Every once in a while the voices in my head have good ideas.
If you can't remove the MS hotfix and you can't install an ADESK hotfix, my question is do you have administrator rights to the computer?
David
I just loaded Inventor 11 on 2 computers and I cannot get text into drawings either... Am I doing something wrong or is there a bug? It's making me crazy!!
I just searched and found that this is a new and common problem due to a conflict with a Microsift Windows hotfix... I downloaded the Autodesk hotfix file for Inventor 11 but I see that it applies to Inventor 11, sp2... I currently have Inventor 11 with no service packs installed... Can I still run the Autodesk Hotfix??... Do I need to upgrade my Inventor to SP2??... How do I do that??
Go to the Autodesk website and download both SP1 and SP2.
David
I downloaded and installed SP1 and SP2... Then I installed the Autodesk patch for the text problem... Working perfectly again... Thanks!
