Disassociated Solidworks BOM
nrbastow
Aerospace
Dec 15, 2010
I am having a problem with Solidworks BOMs. Whenever I open an assembly drawing with a BOM, the BOM table and text are brown, instead of black.
Does this mean it is disassociated with the assembly? Or is a problem somewhere in my system settings?
When you open a BOM, it should you should have to click on the view it associates with. If you insert a BOM on the format layer, views are by definition not active. Maybe that's your problem.
I cannot insert a BOM into a format and I cannot reproduce the brownout condition. If the BOM is an Excel table instead of a SWX table, maybe that would cause the problem. I don't have excel, so I can't test the theory.
Can you edit or modify the brown tables?
"how now, brown BOM?"
Hardie "Crashj" Johnson
SW 2011 SP 2.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
