Discharge head or Differential head
nabeel3
SA
Dears
Which head does the pump curve show?
Discharge Head or Differential head developed by the pump
For a centrifugal pump you need to read the fine print.
It is sometimes (more commonly) Differential, and sometimes Discharge at a specified inlet condition.
The latter is more common with submersibles where the curve may be for discharge at a minimum submergence.
I would say 90% of the time or more it's differential head.
But read the notes carefully.
Dear Edstainless,
What if, the maximum submergence is given for a Submersible pump
Max submergence is the maximum depth that a submersible pump should be installed. I would expect that is the maximum pressure that the pumps seals can handle before starting to leak inside the motor housing.
The submergence of a pump or inlet below water level does not reflect in head calculation other than the friction loss thru' the pipe / hose. As bimr has pointed out, the max submergence given is to ssfe gaurd the motor/pump sealing.
