Pump Suction and Discharge Velocities - Original Pipe or Nozzle Diameter? 1
sweetliver
8
Hi All,
We are going to replace an existing pump with one of a higher capacity (maximum expected operating flowrate is 340 GPM). The suction line size is 6 inch, while the discharge line size is 4". These corresponds to liquid velocities of 3.8 ft/s for suction, and 8.6 ft/s for discharge. However, the pump we are planning to select has flanges of 3" in the suction (6" x 3" reduction nozzle) and 2" in the discharge (4" x 2" increase nozzle). According to the calculated liquid velocities in these reduced sections, the suction nozzle will have a velocity of 14.7 ft/s, while the discharge nozzle will have a velocity speed of 32.4 ft/s.
My role of thumb is to not to exceed 8 ft/s in the suction and not to exceed 15 ft/s in the discharge.
Does the liquid velocity in the nozzle matter, and should I only stick to the size and the liquid velocities of the main lines?
Thank you in advance.
Beware API 14E is specifically for oil production piping on offshore rigs.
Don't take everything it says literally.
From a reputable engineering company in the US.
"recommended" high limits
Pierre
